Rear Mount for R200 diff wanted to suit 280ZX.
Failing to find R180 3.9 ratios for diff. Will fit R200 3.9 with spool that I have. Rear mount slightly different.
  • 2 weeks later...
Cant post photo as the diffs and mount are with the diff man. The rear housing has 2 studs out the rear, only difference is stud sizes and spacing.
R200 have slightly larger studs and spaced slightly further apart. Mount with 1 centre hole bolts up to body. Might have to inspect at wrecker for other Datsuns.
Single drop pin threaded rod from floorpan in your ZX?
If so i got one, ex JDM import series 1, R200 L28ET rack and pinion steering version
The rubber is in very good cond!
$40 posted to you.
