I have just pulled apart everything in the valley of a 84 Z31 and it has a whirhing noise , has somebody tghtenrd the cam belt to tight
Could it be a dud bearing in a pulley? or water pump?
you know your probably rightr Dimetri. i just dont understand if you do a job doo it right and on a engine like this as everything is complicated, i just had to dimantle all the injection as it was leaking fuel and just been done recently and had to recover everything and still not finished just never ends, but i will get it right
They key word is patience
Thanks Demetri your a good Man
