Magnet Posted February 1, 2013 Posted February 1, 2013 Having a hard time finding a fuse box with the right plugs. These are the connections I have; Are they normal 240? Is there another box I can use? Where can I get one? Thanks guys, Ryan Quote
jock Posted February 1, 2013 Posted February 1, 2013 I have a good used fuse box PM me if interested, also is your fuse box mounted behind console under radio ?. Quote
Magnet Posted February 1, 2013 Author Posted February 1, 2013 It appears to be mounted at your right knee, just assuming these plugs are for the fuse box? Quote
Scoota G Posted February 1, 2013 Posted February 1, 2013 And here i was thinking that the 240Z's have there fuse box mounted in the console. Quote
Moderators Zedman240® Posted February 1, 2013 Moderators Posted February 1, 2013 All 240's have their fuse box at the console; only 260's have it mounted on the right kick panel. Where you have pictured, all the looms ie rear, engine compartment and dash all connect there. There should be all matching plugs if your loom is complete. Quote
Scoota G Posted February 1, 2013 Posted February 1, 2013 All 260Z fuse boxes are hard wired. Same for the 240Zs i think. The plugs in your picture are for relays. Do you have a haynes repair manual? Quote
Moderators Zedman240® Posted February 1, 2013 Moderators Posted February 1, 2013 240 fuse boxes do plug in, but 240's dont have any major relays down near the kick panel. Has someone unplugged anything? Quote
Scoota G Posted February 1, 2013 Posted February 1, 2013 Ok i get it, he simply ran the wires to the wrong area. Smell that noob freshness Quote
Retro Z Posted February 1, 2013 Posted February 1, 2013 Having a hard time finding a fuse box with the right plugs. These are the connections I have; Are they normal 240? Is there another box I can use? Where can I get one? Thanks guys, Ryan Those plugs look exactly like what im going through now. I believe those plugs are for relays that mount to the kick panel. Quote
mad680 Posted February 1, 2013 Posted February 1, 2013 There are no relays there from factory, only if someone has modified it. You do have the flasher can for the indicators but. You do have the horn relay over on the LHS. Quote
Magnet Posted February 1, 2013 Author Posted February 1, 2013 Has someone unplugged anything? Bought the car as a rolling shell, just putting it back together with what I have. I haven't connected the flasher can, might be other connections that become available if route it a different way, just quickly assumed something was missing by the look of those plugs. Quote
Moderators Zedman240® Posted February 2, 2013 Moderators Posted February 2, 2013 Are all three of the wiring looms there for each part of the car? I mean the loom for the rear half of the car, the loom for the dash and the loom for the engine/lights at the front half. With all those looms in place, you shouldn't have any spare plugs. There should be a couple for like the door switch, flasher cans etc., Quote
Magnet Posted February 2, 2013 Author Posted February 2, 2013 All the looms are in the car, I connected another plug and spade connector, so left with 2 now What's the thing in the pic above? Quote
Retro Z Posted February 2, 2013 Posted February 2, 2013 They are relays. These are the actual ones i have in my car. I had the 2 exact plugs un-accounted for aswell as one 4 pin and one 6 pin female plug. Now both of the left over plugs and spade connected fitted perfectly to these relays. I think the spade connectors are for horn relay and the 6 pin for ignition relay..not sure. Dimitri helped with my wiring and im sure he can vouch for me. Quote
Magnet Posted February 3, 2013 Author Posted February 3, 2013 That sounds like what I need These are what I have left over now; 2x 4 pins, one with the earth fitting, 2x spade fittings and the single red w/white on the right. I'll track down those relays and hopefully that uses up most of those plugs Quote
Moderators Zedman240® Posted February 3, 2013 Moderators Posted February 3, 2013 That single red/white strip should have another matching one there somewhere... I think those two spade fitting are for the door switch? Is one male and the other female? Quote
Magnet Posted February 3, 2013 Author Posted February 3, 2013 Couldn't see a matching one for the red one but I'll have another look Think they are male and female for the Spade fittings yeah Quote
Six_Shooter Posted February 5, 2013 Posted February 5, 2013 The spade connectors should be for the turn signal flasher. Sounds like it's time for you to download the factory service manual, and start tracing, matching up wires as compared to the wiring diagram. Quote
