. Posted July 29, 2009 Posted July 29, 2009 The Interpretive Guide to the Haynes Maintenance Manual Here is a secret translation of the contents of this manual which you may find helpful Haynes: Rotate anticlockwise Translation: Clamp with mole-grips then beat repeatedly with hammer anticlockwise. Haynes: This is a snug fit. Translation: Clamp with mole-grips then beat repeatedly with hammer. Haynes: This is a tight fit. Translation: Clamp with mole-grips then beat repeatedly with a hammer. Haynes: As described in Chapter 7... Translation: That'll teach you not to read through before you start. Now you are looking at scary photos of the inside of a gearbox. Haynes: Pry... Translation: Hammer a screwdriver into... Haynes: Undo... Translation: Go buy a tin of WD40 (giant economy size). Haynes: Retain tiny spring... Translation: PINGGGG - "Where the hell did that go?" Haynes: Press and rotate to remove bulb... Translation: OK - that's the glass bit off, now fetch some good pliers to dig out the bayonet part (and maybe a plaster or two). Haynes: Lightly... Translation: Start off lightly and build up till the veins on your forehead are throbbing then clamp with mole-grips then beat repeatedly with hammer. Haynes: Weekly checks... Translation: If it isn't broken don't fix it. Haynes: Routine maintenance... Translation: If it isn't broken, it's about to be. We warned. Haynes: One spanner rating. Translation: An infant could do this... so how did you manage to f*** it up? Haynes: Two spanner rating. Translation: Now you may think that you can do this because two is a low, teensy weensy number... but you also thought the wiring diagram was a map of the Tokyo underground (in fact that would have been more use to you). Haynes: Three spanner rating. Translation: Make sure you won't need your car for a couple of days. Haynes: Four spanner rating. Translation: You're not seriously considering this are you? Haynes: Five spanner rating. Translation: OK - but don't ever carry your loved ones in it again. Haynes: If not, you can fabricate your own special tool like this... Translation: Hahahahahahahahahahahahahahahahahahahahahahaha. Haynes: Compress... Translation: Squeeze with all your might, jump up and down on it, throw it at the garage wall, then find some molegrips and a hammer... Haynes: Inspect... Translation: Squint at really hard and pretend you know what you are looking at, then declare in a loud knowing voice to your wife "Yes, just as I thought; it's going to need a new one" Haynes: Carefully... Translation: You are about to suffer deep abrasions. Haynes: Retaining nut... Translation: Yes, that's it, that big spherical blob of rust. Haynes: Get an assistant... Translation: Prepare to humiliate yourself in front of someone you know. Haynes: Turning the engine will be easier with the spark plugs removed. Translation: However, starting the engine afterwards will be much harder. Once that sinking pit of your stomach feeling has subsided, you can start to feel deeply ashamed as you gingerly refit the spark plugs. Haynes: Refitting is the reverse sequence to removal. Translation: Yeah, right. But you swear in different places. Haynes: Prise away plastic locating pegs... Translation: Snap off... Haynes: Using a suitable drift... Translation: Clamp with mole-grips then beat repeatedly with hammer. Haynes: Everyday toolkit Translation: RAC Card & Mobile Phone Haynes: Apply moderate heat... Translation: Unless you have a blast furnace, don't bother. Alternatively, clamp with mole-grips then beat repeatedly with hammer. Haynes: Index Translation: List of all the things in the book, bar what you need to do. Quote
Moderators Zedman240® Posted July 29, 2009 Moderators Posted July 29, 2009 That is so true...my sides acually slpit. Quote
lightmaster240z Posted July 29, 2009 Posted July 29, 2009 sa that were all the blood stain come from. no wonder the book was so cheap Cant Wait for the weekend to do some more blood leting Quote
garvice Posted July 29, 2009 Posted July 29, 2009 I find the problem with most manuals is that they are written when the car is new. For instance Haynes say that they pull the car apart and then put it back together in order to right the book. But there car doesn't have 320000 km's and 15 years of seizing. Quote
pauly_adams Posted July 30, 2009 Posted July 30, 2009 i truely must agree with the "carfuly" in the haynes books, it always seem to end in a new blood test. cheers pauly Quote
