BobsYourUncle Posted February 5, 2012 Posted February 5, 2012 I've got some parts that I no longer need, so buy them and help finance my build! - Mitsubishi electronic distributor, suits L24-28. Needs a clean up, but was working fine in my old 2+2 - $100 NLA - Round top 240z carbs + manifold, have been cleaned up and had a kit but through them (by benny, not me) - $400 Sold - 240z front rotors, a bit of surface corrosion (as you'd expect), but they've still got plenty of meat (~12mm thick) - $100 Sold - Exedy clutch pressure plate, brand new (OEM equivalent) - $30 Sold - 240z front calipers, need a clean/kit/pads - $50 Sold - 260z factory sealed headlights (from '74 2+2), working when removed - $20 - Brand new N1339 brake shoes, suit later model 260z (check yours first, my '74 2+2 needed different ones) - $40 - Standard 240z brake master cylinder (I think these have a flow restrictor of some sort in them, this has been removed in this one) - $50 - 260z 2+2 automatic gearbox (has torque converter, but no flex plate) - free, come and get it before it goes to the dump next weekend Quote
Patch Posted February 5, 2012 Posted February 5, 2012 Pm for the clutch , will take if not taken. Quote
BobsYourUncle Posted February 6, 2012 Author Posted February 6, 2012 Couple of parts I forgot about: - Brand new N1339 brake shoes, suit later model 260z (check yours first, my '74 2+2 needed different ones) - $40 - Standard 240z brake master cylinder (I think these have a flow restrictor of some sort in them, this has been removed in this one) - $50 I can post photos of these if needed. Quote
BobsYourUncle Posted February 12, 2012 Author Posted February 12, 2012 Bump - carbs and pressure plate sold, open to offers on the rest! Quote
BobsYourUncle Posted July 29, 2012 Author Posted July 29, 2012 Ok, I cleaned the garage on the weekend, and I need this stuff gone. Everything $20 each ONO (except the auto gearbox, which is still free) - 240z front rotors, a bit of surface corrosion (as you'd expect), but they've still got plenty of meat (~12mm thick) - 240z front calipers, need a clean/kit/pads - 260z factory sealed headlights (from '74 2+2), working when removed (may have thrown these out, will have to check) - Brand new N1339 brake shoes, suit later model 260z (check yours first, my '74 2+2 needed different ones) - Standard 240z brake master cylinder (I think these have a flow restrictor of some sort in them, this has been removed in this one) - 260z 2+2 automatic gearbox (has torque converter, but no flex plate) Quote
BobsYourUncle Posted August 1, 2012 Author Posted August 1, 2012 Calipers and rotors are sold. Everything else is now FREE!! (pickup only, I'm not posting if I'm not getting any money) Quote
