Search the Community
Showing results for tags 'jasf 45 dcoe carburettors'.
  • Search By Tags
    Type tags separated by commas.
  • Search By Author
  • General Forums
    • Introductions and Forum Etiquette
    • General Discussions
    • Off Topic Discussions
    • Events
    • Business Directory + Links
    • Members Project(s) Journal
    • Racing Your Car
    • Website Feedback & Club Discussions
    • Donating Members Only
  • Technical
    • General Maintenance
    • Technical FAQs
    • Body work
    • Brakes / Drivetrain Components
    • Electrical systems
    • Engine
    • Fuel Systems
    • Gearbox
    • Interior
    • Suspension
    • Tools and Equipment
    • Wheels and Tyres
  • Classifieds
    • Cars For Sale
    • Parts and Tools for Sale
    • Wanted
  • Auszcar Sponsors
    • Otomoto
    • Moorabbin Auto Spares
    • Classic Auto Fabrication
    • Automotive Panel Craft
Categories
  • Articles
    • Forum Integration
    • Frontpage
  • Pages
  • Miscellaneous
    • Databases
    • Templates
    • Media
Product Groups
  • Body
  • Interior
  • Brakes
  • Engine
    • Carburetor
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
Website
Location
Tagline
Found 1 result
  1. Hi Everyone, Has anyone here had any first hand experience with the Chinese Knock Off Weber 45 DCOE carbs. I would like to hear from someone who has them fitted to a 260Z L28 engine. Preferably anyone who has them running well. I have a set on my L28 but they will not idle correctly. This is a fully reconditioned L28 with a 60 thou overbore. Standard cam, reconditioned N42 standard head head and block. Flat top pistons. All new timing chain, gears, guides, and tensioner. Set on position 1. 1. I have checked and rechecked the timing several times and it is absolutely correct. Currently set at 12 degrees advance. 2. Checked and rechecked the valve clearances and they are absolutely correct as per the book. 3. New points correctly set. New condenser. 4. Mixture set using a Colourtune spark Plug (nice blue flames in the chamber) 5. Re-Jetted the idle jets from 55F8 to 50F8. Made slight improvement but still wont idle below 1850 rpm. This is with the butterflies fully closed. 6.Some backfiring through the carbys. Re-jeting improved this but not fully sorted. 7. Engine starts dieseling when ignition switched off. 8. Fuel pump is Carter P4070. Fuel Regulator set at 2.5 psi. Any more and the carbs flood. I've tried to check the actual pressure but it will not read on the 0-15 psi gauge. Is running a fuel return line to the tank. 9. Float levels are set at 12mm. Checked and rechecked. If anyone can suggest what else I can try short of chucking the JASF Weber knock offs and fitting genuine Webers help would be greatly appreciated. Best Regardsw, Champ 54
