zed4ps
Everything posted by zed4ps
  1. zed4ps
    260Z Bonnet
    Hi, i am chasing a 260z fluted bonnet, darn skippy, i live north brisbane, if you can help me out that would be great, thanks
  2. hi, thanks for that, but what i realy need to know is the yellow datsun wire goes to which wire Honda wire and so on as all diagrams on the forums are for 240z which are different. Thank you for your reply,
  3. hi, i have purchased a honda civic wiper motor for my 260z, problem is all wiring diagrams on the forums are for 240z which have 5 wires. My 260 has 6 wires and the honda has 6. Datsun yellow, 3x black (2 Soft ) blue/white, blue red. Can anyone help with a wiring diagram for a 260 as i have already burnt out 1 honda wiper motor. Cheers Peter Ps i am pretty sure the 2 soft black ones are for high and low speed but i dont know where to attach them with the new wiring.
  4. Thanks very much for all the info, i will see how i go and put up what i find. Once again thanks.
  5. The injectors are new but that doesn't mean that they are working proply, i took out the cold start valve left it hooked up, and filled the hole with another one. Ran car but no fuel came out of the c.a.v. I have new fuel pump, new temp sensor, on the bottom of the throttle body there is a boost controlled deceleration valve but nothing electrical or air is hooked up as i can`t find any info on this device, or if i even need it. the dyno guy said not to use vac advance setup. Cheers
  6. Thanks guys i will give that a try today.
  7. Hi, i have a 260 with a series 1 280zx engine and efi. I am trying to find out if i have the right computer for the series 1 or if there is a couple of options. The numbers i have are 22011 P8800 ALL-000 450 oyo5. had the car dynoed and it runs well except when sitting at lights or at rest somewhere i can smell what i think is unburnt fuel. if i sit at lights and then plant it it blows out black smoke for a while and then stops.Any help would be appreciated. Cheers
  8. WOOPS: Was playing with the air flow meter on my series 1 l28 efi engine when, you guessed it, i let go of the spring. Anyone know of a way to reset the spring back to a starting point of which i can then advance to a better setting? Any help would be appreciated. ( Things we learn as we play with our cars ) Cheers Peter
  9. Problem solved, replaced two new spark plugs with another two new ones. Realized you cant run a hose from the outlet on the side of the block to the manifold as this bypasses the air flow regulator and is not considered in the mixture of the air fuel. Thanks to everyone for their input into my problem. Cheers Peter.
  10. Hi, i have had the motor rebuilt, new injectors ECU checked out, new temp sensor, new fuel regulator and spark getting to all plugs. Not sure if the spark is strong enough due to the points dizzy. Will check other options . cheers peter.
  11. Hi, Does anyone know if you can run a standard points dizzy with the l28 and EFI. car is running at the moment but not very well, runs rough and backfires. Sounds like it is running on 4 cyl`s. When i take the leads off 1 & 5 plugs while motor running it makes no difference. Cheers peter
  12. I also have done this mod but my hand brake lever has to be fully engaged before the park brake applies. Would this mean that the cable is stretched and needs to be replaced, as i have adjusted it a fair bit. Cheers peter
  13. zed4ps
    Black Smoke
    pddl4@bigpond.com Thanks, Peter
  14. zed4ps
    Black Smoke
    Cheers , i`ll check it out.
  15. zed4ps
    Black Smoke
    Have no idea , how do i test? cheers Peter. Thanks for the reply
  16. I have recently changed my 260 to a l28 injected motor. i have had the motor and head reconed now when i get the car started it blows black smoke ,runs rough and won`t start when warm. Have fitted fuel injection fuel pump as well as surge tank new fuel regulator and am running out of ideas, any help would be great. Cheers Peter.
  17. Hi, i have bought 2 dizzies from people and both have broken breaker plate assemblies. anyone know where to purchase them. Cheers Peter
  18. I have a 76 260z 2+2 and i am looking for a body kit, one that replaces the old bumper bars with bumper and spoiler built into one another, also side skirts. Thanks
