Does anyone know where the 240z flasher can wiring ends up (the green + wire).  I had no turn signals and checked the flasher and no 12v, linked a 12v wire to the can and the turn signals worked so just want to trace back the green wire.
Its a 71 so no hazards
All zeds have the wiring for hazards; they have that "loop back" plug that takes the spot for the hazard switch. Check your indicator switch on the steering column..make sure no wires have come off.
  • 2 weeks later...
Checked the steering column and all wires are intact but there isn't any voltage going to either of the 3 wires on the signal switch, also have a new flasher installed. Also found that hazard plug but nothing plugged in.
If that "loop back " plug isn't in, you get no indicators... Make sure it is the right part of the loom; all green wires with various coloured stripes in a small condensed multi pin plug from memory.
Looks like you need that plug. I might have a spare floating around. Once its installed, it gives power to the circuit. Takes the place of the hazard switch.
Dimitri I might not need that plug, if I just make up a spade connector and loop it into the 2 connectors in the plug my turn signals seem to work fine, thanks for your help  ;)
