zr240 Posted September 21, 2011 Posted September 21, 2011 Hi Guys Got a special on Fullriver HC20 AGM battery. I use one in my road zed. I relocated it to just behind the passager seat. I have found them really reliable and afetr weeks of being in the shed start up the car no prob. Also doing a special on the Projecta charger to suit, this has the extra loom that stays connected to the battery and plugs directly into the charger so you can leave it on and it keeps the battery topped up. HC20 AGM battery $165 inc GST Projecta charger $55.50 inc GST Or $200 as a package deal. Call, PM or email to order Thanks Ash Quote
luvemfast Posted September 21, 2011 Posted September 21, 2011 Dimensions and weight? Cranking amps? Quote
benny Posted September 21, 2011 Posted September 21, 2011 Dimensions and weight? Cranking amps? pretty sure it says it on top of the battery- CRANK AMPS (CA)- 310 COLD CRANK AMPS (CCA)- 230 heres spec sheet- http://www.fullriver.com/products/admin/upfile/HC20.pdf Quote
luvemfast Posted September 21, 2011 Posted September 21, 2011 pretty sure it says it on top of the battery- Cheers Benny, looking on my phone while watching Sons of Anarchy. God I love that show. I'm interested Ash, but Peter is taking all my money at the moment. Hopefully you have ghid deal for a little bit Quote
zr240 Posted September 21, 2011 Author Posted September 21, 2011 Thanks Ben (will have to put you on the pay roll Yer I will keep the deal for a while (or till the put the buy price up). Ash Quote
neRok Posted September 22, 2011 Posted September 22, 2011 ive been looking for a battery just like this (odyssey alternative). how much to post? Quote
zr240 Posted September 22, 2011 Author Posted September 22, 2011 HI Post to WA 6000 is $35 by aus post or $20 by e-go courier. If you want exact price let me know you postcode but it should be around the above price . Thanks Ash Quote
kobes Posted September 22, 2011 Posted September 22, 2011 Hey, ash will take a stab and Benny mentioned I should contact ash at MAS, gunnz join some dots and guess I found ya. What I am looking for is a fan clutch for my l26 260z ( rev zeds old car) I not the most knowledgable fella but my mechanic said the old one has heaps to much movement and is on last legs. don't need the fan just the housing Thanks if ya can help Quote
zr240 Posted September 22, 2011 Author Posted September 22, 2011 HI Kobes Fan clutch is $64.95. Its a good quility US motor works one. It should go in a 3kg bag so postage would be $11.20. Its just the clutch without the fan that bolts on. Ash Quote
neRok Posted September 22, 2011 Posted September 22, 2011 HI Post to WA 6000 is $35 by aus post or $20 by e-go courier. If you want exact price let me know you postcode but it should be around the above price . Thanks Ash cool, thanks. i will wait til you get some fans in stock and might order a bunch of things at the same time. Quote
Riceburner Posted September 23, 2011 Posted September 23, 2011 Hey Ash, I'm interested. Will it have enough grunt for my L28 with a comp ratio of 9.8:1? I have a gear reduction starter. Also can I get an extra charge kit separate? So two charge kits and a battery. Cheers, Gareth. Quote
kobes Posted September 24, 2011 Posted September 24, 2011 HI Kobes Fan clutch is $64.95. Its a good quility US motor works one. It should go in a 3kg bag so postage would be $11.20. Its just the clutch without the fan that bolts on. Ash Sent you pm Quote
zr240 Posted September 26, 2011 Author Posted September 26, 2011 Thanks kobes replied Gareth it should not have a prob as I used it on my race motor with the rb25det starter but I am happy to give you mine to try and double check it can crank it ok. The charger kit is availble seperate and will give you a good combined price Ash Quote
Riceburner Posted September 27, 2011 Posted September 27, 2011 Thanks Ash, I'll swing past one day and have a look. Quote
zr240 Posted April 10, 2012 Author Posted April 10, 2012 Hi All Just a reminder when do these full river batteries which are great for club/ track cars Ash Quote
luvemfast Posted July 9, 2012 Posted July 9, 2012 Hi Ash, Can you supply me a package for this to move into my cabin. I'll need to work out how many meters of cabling I'll need. But essentially- Battery Charger Isolation switch Wire/cable connectors/terminals thanks, Simon Quote
PZG302 Posted July 9, 2012 Posted July 9, 2012 Hi Ash, Can you supply me a package for this to move into my cabin. I'll need to work out how many meters of cabling I'll need. But essentially- Battery Charger Isolation switch Wire/cable connectors/terminals thanks, Simon Simon, for the isolation switch spend the extra on the metal ones, including key, they last a lot better than the cheaper plastic ones. You know when the switch has operated by the big clunk when you move the key from on to off. When I go mine it was about $50 from memory. Quote
zr240 Posted July 10, 2012 Author Posted July 10, 2012 Hi Simon Just saw this now. Will work/price it up tommorow for you. Can give you option for metal isolation switch if you like. I have been using the same plastic one for about 10 years without a prob but it was the good quality one. Ash Quote
