A while back there was a thread upon the straps designed to hold the luggage in.  I and a number of others
indicated interest  :) .  The intent was to get new black webbing and form the "brackets" from stainless of
the same sort of thickness. Then silence. :'( Has there been any progress please?
Marcus
I have to replace one strap and a buckle. I will probably source the strap from Clarke rubber I may make the buckle from brass or mild steel stainless ,could be difficult to work.
Thanks for the idea that Clarke might have the webbing... :).  I have found a set of straps on Ebay in the meantime. :-\
The original concept was to laser cut the brackets from thickish stainless.  I would still be in it if someone would do it.....
Marcus
