Hey Guys, After fitting the RTZ diff mount with urethane bush I have noticed a clearance problem. With the car on stands, the suspension at full droop.... the sway bar is touching the diff pinion to prop shaft flange  :o this wasn't happening with the ols solid mount.
Will this be an issue? I do have a fair bit of pitch on track under heavy breaking and initial turn in. How do others with RTZ diff mount go?
