OK, jumping right in with a question, not boring you all with about ME stuff.
My ZX is back on the road after having a rear end ruin my exhaust and bumper.
The mechanic told me that my 22 year old rear wheel bearings need replacing and suggested I ask consolidated bearings to replace the bearing in the bearing mount.
Has anyone done this before?
CBC want to know which bearing spec they should use?
Well without boring you with the answer........ sometimes an introduction helps  ;)
Have you got a Haynes manual? They would most likely give you the answer.
Failing that, take out the old bearings and match it at CBC.
thanks for reading.
CBC looked up the Timken bearing and suggested that I just buy it.
They advise owners NOT to attempt repacking bearings.
