OZZ240 Posted April 3, 2012 Posted April 3, 2012 Looking for a couple of R200 diffs out of Z31's with diff ratio of 3.5 with open centres as already have the parts to make them LSD and does anyone have one or two or where I could find one or two? also possible a set of axles as well out of a Z31 turbo Cheers Ian Quote
Whittie Posted April 3, 2012 Posted April 3, 2012 Hi Ian, I'm not sure if they're a different casing, but if you can use a 260z Long nose R200 with an S14 viscous center then I have one here. Viscous 3.54 R200 center from an S14 silvia with modified ring gear bolts to fit in a zed R200 casing. I'm fairly sure I still have modified stub axles (cut and welded) with zed 4 stud ends welded on too. Essentially brand new, I only did about 2,000km with this diff in the car after I had it re-shimmed and professionally rebuilt. Drop me a PM if you're interested Quote
OZZ240 Posted April 3, 2012 Author Posted April 3, 2012 Hi Whittie, Its for a friend of mine and unsure if there is any difference in the diff housing either he just said he was chasing a R200 out of a Z31, will have to ask the question. I need to update the info as he only wants open centres I think he must have LSD internal. Cheers Ian Quote
z31(L) Posted April 11, 2012 Posted April 11, 2012 Hi Whittie, Its for a friend of mine and unsure if there is any difference in the diff housing either he just said he was chasing a R200 out of a Z31, will have to ask the question. I need to update the info as he only wants open centres I think he must have LSD internal. Cheers Ian Hey mate, I got an open centre longnose r200 and drive shafts from a z31. You can have the package for $250 picked up from Acacia Ridge. Cheers. Quote
