53-681 Posted January 23, 2012 Posted January 23, 2012 (edited) Hello guyz, I have recently purchased a full 280ZX EFI assembly from Zac, and it turns out that I won't be using it since I've gone another route... Quote Hey Sam, It's the manifold, the harness, the injectors, the ECU, the AFM and everything associated. It came off a running engine which was put on a pallet, plastic wrapped and stored in a warehouse for a few years. I once got a ZX with EFI running after 2.5 years of sitting idle in a friends front lawn, so I would imagine that this would be functional given that you clean up the injectors, the injector plugs and give the manifold a clean! I'll get you a quote and send you bank details! Thanks Zac I purchased it for a total of $94 including delivery from Zac, so it would only be fair if I sold it for the same amount. By the way, I still have not taken anything out of the box that it was delivered in, so will be posted out in same package. For those that are curious, I am still using the Jag HS8's... (Dazzed is tuning them) Kind Regards Edited August 7, 2021 by 53-681 Privacy Quote
bigVee Posted January 26, 2012 Posted January 26, 2012 Sounds good Im looking for one at the moment How much was the postage roughly Im in Shepparton, Vic Quote
