Hi all,
I am after the fitting off a 260Z inlet manifold for twin carbs as pictured below. Must be identical to one below as I am running A/C and auto transmission. Please let me know if you have one of these. Cheers. :)
Cheers Dimitri, I am also chasing a hazard switch for a 1977 260Z 2+2 (series 2) if you have a spare. Let me know. PS will you be at the F1 this year? I will be coming down for that so will see you there if you are at the track. Cheers
With the hazard switch, what plug is on the end? the white one with the round pins or smaller rectangular with the blade contacts?
Thanks Dimitri will check it and get back to you. Are there only two wires that run to the connector as I never got a switch with my car. Cheers. :)
