drzoidberg Posted October 31, 2011 Posted October 31, 2011 hey iv got a walbro pump im stickin into my 280, the pump originaly off a vl turbo ive encountered a couple of un certanties, it doesnt have any indication as to the direction of flow, im assuming its inlet is the terminal side and 280s dont have a low pressure in tank pump as i think most other efi cars do, will the new pump suck fuel or do i need a priming pump? any knowlege be much apreciated. cheers fellas Quote
pauly_adams Posted October 31, 2011 Posted October 31, 2011 it will suck the fuel fine, i have one installed in my 280zx it can run 100psi and i had no trouble. cheers pauly Quote
Six_Shooter Posted October 31, 2011 Posted October 31, 2011 Are you sure it's a genuine Walbro? There is a flow indication on the genuine parts. You can just make out the arrow in this picture: Quote
nizm0zed Posted October 31, 2011 Posted October 31, 2011 to add to that, there is also a LOT of fake chinese Walbro's on the market, They are an identical copy, even down to the colour of the plastic end cap bit. The bit where they arent a copy is the flow figures, they are around 20% lower than a genuine one. http://www.fuel-pumps.net/walbro-forgeries.html http://www.google.com.au/#sclient=psy-ab&hl=en&source=hp&q=fake+walbro+fuel+pump&pbx=1&oq=fake+walbro&aq=1&aqi=g4&aql=1&gs_sm=c&gs_upl=0l0l1l5969l0l0l0l0l0l0l0l0ll0l0&bav=on.2,or.r_gc.r_pw.r_cp.,cf.osb&fp=367931643464da19&biw=1466&bih=753 Quote
drzoidberg Posted October 31, 2011 Author Posted October 31, 2011 ahh you could be right about the fake part, i didnt buy the pump from a shop it was out of a vl turbo my friend crashed which ran well but who knows where it actually came from. If it is a knock off funny they forgot the flow direction part. I'll just buy a genuine one turbos dont like runnin lean. cheers fellas Quote
Moderators Zedman240® Posted October 31, 2011 Moderators Posted October 31, 2011 Last pump I removed from a VL was a Bosch unit about the same size as an ignition coil. Low pressure ends have usually a larger hose fitting than the high pressure side. Quote
Six_Shooter Posted November 1, 2011 Posted November 1, 2011 Last pump I removed from a VL was a Bosch unit about the same size as an ignition coil. Low pressure ends have usually a larger hose fitting than the high pressure side. On the (genuine) external Walbro the inlet and outlet are the same size. Quote
Moderators Zedman240® Posted November 1, 2011 Moderators Posted November 1, 2011 On the (genuine) external Walbro the inlet and outlet are the same size. On a genuine Bosch pump that comes in all VL Commodores, in is larger than the out. I wasn't referring to Walbro pumps that must've been installed in that car. Quote
drzoidberg Posted November 1, 2011 Author Posted November 1, 2011 your 100% right about the inlet outlet sizes in the vl but i unscrewed em ages ago to use for sumthing else so i cant identify from that unfortunatly. I fit it up last night so i could move the car and it was pushing fuel in the right direction so it is flow toward terminal. not getting any meaningfull line pressure tough i think the pumps stuffed sitting around too long maybe Quote
