Hi, what is the difference between solid cams and drilled cams for oil flow and can you mix and match. eg use a drilled cam with oil spray bar as well. ???
Thanks Peter, got my car back today from engine builder and he fitted a new cam {drilled] but it still has a lot of tappet noise. He is at a loss to what is happening but at least he didn't charge me anything. Said to take it back if it gets any worse.
Will domate but may take a while as I have to go to CQ on Sunday. See how I go tomorrow. Thanks for your advise. 8)
