Bludat Posted July 23, 2011 Posted July 23, 2011 My oil pressure/ temp guage on my 260z reads intermittent. Some times they both read correct. Have put a light to guage which lights up for about 1 second at a time then goes out.When globe lights up then oil pressure and temp guage move up in unison.Have checked connection at sender units.Both guages moves together when driving along, going up then down.Bizzare. Quote
Moderators Zedman240® Posted July 23, 2011 Moderators Posted July 23, 2011 Sounds like a break in the wire or a poor connection on the sender connections. Ground them both and make sure the gauge reads full deflection and then play with the wire. If it goes down, there might be a break in the wire further away from the connector. Quote
Six_Shooter Posted July 23, 2011 Posted July 23, 2011 Since it's two separate senders I wouldn't start there. What I would look at is what is common between the two gauges, that being the ground and the switched ignition. I would inspect the plug for that pair of gauges, it might be melted, corroded or just old and failing. There might be a break in the main harness, that the ignition and ground split off. Quote
Bludat Posted July 24, 2011 Author Posted July 24, 2011 @Six Shooter,What do u mean -----break in harness that the ignition and ground split off.Im some what slow when it comes to auto elec Quote
Six_Shooter Posted July 24, 2011 Posted July 24, 2011 A wire's conductor could be broken. this is especially common in older vehicles or vehicles that use thin gauge wiring that is not supported well. To feed all the items that need to have an ignition or even a ground supply, the wire will be tapped into or split, to allow many devices to be fed from one source. Sometimes these joints can be the source of failure, or where the conductor is broken. Quote
Moderators Zedman240® Posted July 24, 2011 Moderators Posted July 24, 2011 Reason I start with that is when some people remove plugs, they tend to pull on the wire rather than the plug itself causing a break in the conductors a bit before the plug. Could be a corroded connections on the fusible links, anywhere really. Quote
Six_Shooter Posted July 24, 2011 Posted July 24, 2011 Reason I start with that is when some people remove plugs, they tend to pull on the wire rather than the plug itself causing a break in the conductors a bit before the plug. Could be a corroded connections on the fusible links, anywhere really. I would agree, if the symtoms were different, as in affecting on one gauge, or at different times, but since they work in "unison," I can say with 99% sureness that it's a power issue, maybe even internal in the gauge... That's something else to check, especially if the power supply seems to stay solid, check the connections inside the gauge. I've had more than a few pieces of electronics come back to life or start work properly after going over the solder connections and re-flowing them. Quote
