I have an rb25det neo that has a blown head gasket, it has no box or ecu or loom or coilpacks, the rest is there including the standard turbo and manifold. I'm interested in swapping for a complete l28et or a modified l28 with injection or triples, btw I also have for the rb a z32 afm, bellhousing to match up to 260z box, rusty flywheel, pressure plate and hd clutch and an rb20det ecu which can be used for this motor if you use an rb20 loom and coilpacks and a Patrol rb30 rear bowl sump that just needs to be welded up as I've cut the extension out. Pm me if you're interested, cheers, John
