Looking for some advice...
Both doors on my '74 2+2 don't seem to fit properly. I've attached some photos to show what I mean. The front top corners (of the window frame) hit the car body when closing. It's like the stainless frame isn't the right shape for the door opening? I was under the impression that the doors were the same shape for all models, is that right?
If you take your door panel off you will see all the window frame mounting points
are adjustable, then when thats done adjust the glass to suit, fiddly job. good luck
