Model: 1981 280ZX 2+2 + spare parts 280ZX
Item Condition: Good - Fair condition
Body: Rust removal and respray approx 5 years ago. since then has had paint chipped off just above left hand tail-light with some surface rust there now.
Mechanical: Needs a battery but runs easily.  Possible diff whine (cannot remember which car had this) Brakes and suspension need attention.
Price and Payment Conditions: I am not trying to make money here, just pass this on to someone who will use it so lets say $3000 neg? QLD prestige plates "RED ZX" are negotiable.
Registration: Not registered, has not been register for approx 2 years.
Engineers Certificate: Mod plated for engine swap in QLD.
Extra Info:
Car was originally L28e and 5 speed. Currently runs an RB20DET with matching 5 speed manual. Stock Diff.
Exhaust is custom 3inch dump into full custom 3 inch mandrel bent exhaust with 1 high flow muffler. Sounds good at idle and not too OTT.
Intake is K&N pod mounted on 90* pipe to turbo, then 450*300mm FMIC in front of the Radiator.
ECU is a professionally wired EMS 8860 with custom tune on a dyno. 221rwhp on standard boost (dyno sheet available).
Brake discs are shot and callipers probably are too, but I have a spare 280ZX that will go with this one to pillage parts from.
Suspension is still stock.
Interior is in decent condition, carpet has some tears and seats might have a hole or 2 (been too long to remember) But it is still comfortable.
R200 diff, I think it might have a slight whine in it.
Wiring needs attention, as the headlight switch stopped working, but indicators still worked fine, so I just ran relays and 3 switches in the dash near the stereo for my lights. Again you could steal this stuff from the spare 280 I have and swap it over if you wish. As a result of my headlight wiring there are some random wires under the bonnet that need to be tidied up.
I need the money to get my Classic falcon ready for the road. Out of all the cars I have had this is the one I miss driving the most.
Pictures: I will get pictures up soon, car is at my parents place in the shed so I need to shuffle things to get it out/clean it up.
Contact Details: Best way to get in contact is PM / Email
Forgot to mention that the car has done about 30,000km with the RB20DET, and it never let me down.
The engine got a new timing belt when I did the swap.
