53-681 Posted January 7, 2011 Posted January 7, 2011 Hey guyz, I require the cover under the steering wheel which hides all the cables, etc. And also the key barrel mounts onto... I am on a tight budget, but reasonable Quote
zeds4ever Posted January 7, 2011 Posted January 7, 2011 Hi 53-681, turns out that I have one sitting around. It needs a little bit of fixing but quite repairable. You can have it for (Postage cost). Scoota G & Lurch were good to me, so why not do the same. If it works OK for you a donation to the "Site" would be appreciated .Send me a PM Re :Name & Address. Regards:Alan. Quote
zeds4ever Posted January 10, 2011 Posted January 10, 2011 Hey mate your steering clmn plastic covers are on their way. Put in an xtra piece that you might be able to use for minor repair to one screw post. Recommend "Araldite" for securing post. A little piece of plastic on other problem & drill small hole for securing screw. Don't put screws in to big or to tight as this is what bugga's them up. Regards: Alan. Quote
. Posted January 10, 2011 Posted January 10, 2011 The posts in mine are gone too. I just joined two cable ties together so they would reach all the way around. The plus side is it only takes a snip to get in there again. You don't notice the cable ties because they are black. Quote
