Hi guys. Have a L28et Auto gearbox complete with lines, shifter, torque converter and ring gear to give away. Was in running order before i removed last week). Looks and drives well..cant tell you much more than that.
Free to pickup from . St. Albans, Victoria. (near Calder Park) First to PM or post gets it.
Thanks Tai
Some one should pick this up. They must be built stronger than the standard autos. Probably have a higher rpm stall convertor too due to the turbo lag on these engines. I'd be interested in having a look at the valve body too.
Can pick up in the 1st week of January if its still available. (perfect timing, my L24e auto has truly shat itself)
Good candidate for the 'RB30x shift kit'
