Some time down the track I am thinking of building up one of these two engines. Would there be any practical reason stopping you getting the same power out of the L28ET as the RB30-26? Obviously the L28 is only single cam, but what would be the limitations of either engine when going for 500+ BHP? Thoughts would be appreciated. Cheers. :)
  the only limitation is the l28 is going to cost 15000 dollars .plus ecu and fuel system and clutch that will cope with 500hp at the wheels. mind you the rb30 26 wont be much cheaper
check out a guy named big phill i think his user name is turbo280z or he is getting over 400rwhp on stock internals from his l28et his car is a beast
Ps. next time maby do a search this has been covered many times on this forum
