I am trying to find the missing wire for my factory temp gauge. It was not on the sender in the thermastat housing and I can't see it laying about in the engine bay. At which point in the firewall does this wire come out of the cabin and enter the engine bay? Photos may be a help.
All wires for under the bonnet come out from the firewall near the brake booster. Temp sender wire is a yellow one and is grouped with the coil/distributor wires as the go from the engine bay side to the engine near were the coil is. Most of the time they are in a black plastic tube so they can't be seen easily. You should see the coil negative cable from the distributor go into a black sleeve; temp wire should be there with it.
Unwrap the wiring loom from where it comes through the rad support panel near the coil; less wires and the best chance of finding it there.
