I have to buy new brake lines, that run from the caliper to the hose for the front brakes, they are about 8 inches long. You know the part? So I rang the Z shop and he asked what are they worth to me, I said not alot. So what should I pay for these. I need one for each side ofcourse.
$40 for the pair? These are the steel line before the rubber line from the caliper...
If you have the originals, (and are in Melb of course) go to Better Brakes in Cheltenham next to Moorabbin airport and they will make you a new set for less than $40.
Dont risk used  brake lines, 35 + years old the rubber ages and hardens........... either get them made as Dimitri has suggested or buy geniune.........I believe these are still available from Nissan
I believe he's talking about the rigid lines, not rubber.
Yes, I was talking about the rigid Lines. Spent $50 and got those, some brackets and clamps etc for around the car.I was happy with that. I wouldn't risk my life with old rubber lines when ADR braided lines are cheap as chips these days. And new rubber lines are cheaper again.
