where can i get the book jags that run.and brand of headers for 350 chev into 260z ?
help john h
ps why cant i use a t5 box from  off the 350 imports and if not what is better for road use ?
I threw a set of Chev Headers out that suited a Zed years ago. That was because I changed the position of the motor in the  engine bay plus went larger diameter.
Your best be would be to get a custom job done. Block huggers will restrict air flow unless you are running a low powered V8. In which case I would question "why bother doing the engine swap in the first place". But that's just me.
i get your point the mod was done back in 1996 and iwant to tidy the mess up and go manual as i dont want an auto
