  • 2 weeks later...
I just pulled an R200 out of my 260z.
it has a 4 bold mounting for the shafts coming out either side.
I have no idea where i get this spline business, if i have any, or what the go is.
I just want LSD, will the R200 you have there help me?
If that R200 LSD is the same as mine, it will fit your zed. All you have to do is pop out your output flanges from your open R200, swap the left/right hand shafts to install into the R200 LSD. With that 4.3 ratio, be prepared to climb walls with that.
