dat2kman Posted December 17, 2009 Posted December 17, 2009 Cast Iron, unequal size pistons, but, there is four per caliper! Throat width is 23mm, so yep a narrow vented rotor, or run a stock solid rotor with some spacers behind the pads to prevent pistons coming out too far ( Spacers? easy get some old pads, grind off the pad material, and hey presto, some pad backing spacers!! $250 the pair Located Westside Brisbane, or can pack and post at extra cost, or if you can wait!!, I can deliver to Melbourne next March ( phillip Island races) jason Quote
