Hey Guys,
Parting out my 260z 2+2 if you want any thing let me know by PM and ill see what i can do.
Basically complete less motor, rear lights and fuel tank.
Cheers Jacob
hey guys
Car no longer has
front air dam
struts
front seats
engine
gearbox
mount kit eg gearbox cross member
rear lights
As for the rest yep I should still have it.
Cheers Jacob
Hey Lex,
I'm after interior door trims...have you still got them and if so what sort of condition?...
...and would you freight them to Perth?
Cheers Philthy
Hi Lex, Would you have a 260Z steering wheel available as mine has had an overdose of sunshine. Or if anyone else may have one. Please let me know ASAP Thanks.
lex i am after the throttle linkage that sits near the firewall that is a boomerang shape that has step down in it and also the long accelerator rod with the cups at each end which also runs along the firewall that connects to it - also i am after the front quarter seals that screw into the front of the quarter windows which seal the window on the door frame when you shut it however i need it to fit onto a 2 seater 260  window frame - (i dont know if there is any difference in the length of the window join to 2+2) regards Paulz
