lol. I had the same thing with my profile ages ago.
You can change the time offset if you go into your profile settings and I think it's under "look and layout" or something like that, then change the default value (should be 0) to 2.5 or whatever you need to bring it back to the correct time.
Cheers,
Rob
Cheers,
Rob
Yer iwas adjusting the profile setting and posting, would be easier if the forum default was set correctly ;)
