I found that the reason (the hard way) why these break is if they are incorrectly adjusted. They need to travel almost full length before activating the mechanisim. 180B ones will fit with a slight bit of filing to make them squeze in. I know of two 180B's in Ballarat if people are looking (rally) to get some parts.
I've heard 120Y door handles also fit.
Also handles are interchangeable from drivers side to passengers side, since they have the lever thingo the rod pops into on both ends.
So it should be possible to swap your drivers handle with the passengers handle and have 2 working doors again.
Cheers I will try that first.
