T.A.P Posted August 24, 2009 Posted August 24, 2009 Taking a break from installing the air-con unit I decided to put in a different armrest and cut the center console back to where the shifter is. The armrest it self has four cupholders, 2 front 2 back, coins compartment and it can slides I got an armrest from a 6gen celica, st202 BEAMS to be specific. With a grinder and electric drill and 2mm plate I got myself a bracket. Dont worry if the bracket isn't measurements perfect, you wont see it anyway. Good thing is that you can slide the top and lock it in any position you wish. I slide it all the way back to cover the plate and there it stays. Flash on and my cam start acting weird. Need to cover the exposing metal but that will be another day. Quote
