T.A.P Posted July 12, 2009 Posted July 12, 2009 My Z doesnt have hazard switch and the indicators still works, Im guessing the indicator circuit must be hardwired. Im trying to figure out which wires are for the hazard and which ones are for the indicators. But what really bugs me is when ever I plug in one of the black connector and turn on the illumination the fuse would blown in about 3 seconds. Here are the location of the two connectors, located underneath the driver's side close to the center console. Here are the two connectors, the left one is a male when left connected will give me indication and possibly defrogger (I have not tested it yet) but when ever I plug the right one (female) in and turn on illumination the fuse would get shot. Now the red arrows mean the two wires are connected the blue arrow means it goes to the defrogger switch, yellow is (Im assuming) goes to the hazard switch (of which two wires were cut out) the gray arrows represent two wires joining each from a connector...and so many left unconnected...what are they for? All wires are black with the exception of a black and white stripe in each connector. Please chime in if you have any ideas. Thanks. Quote
T.A.P Posted July 12, 2009 Author Posted July 12, 2009 Update : Defogger wouldnt work without connecting the right plug in, but that would result in a blown fuse with illumination. Quote
