I need to replace my syncro rings but want to know if i can do it myself or do i have to get a mechanic to do it? I have asked 3 mechanics to give me quotes but none have called me back and when i revisited, none knew anything about it.. Didn't inspire confidence in me so i thought maybe i could do it myself?
I know i can get the rings from SW Motorsport so it's just a matter of replacing them....
OK... seeing as you wont listen to me on MSN, it'll be here.
I replaced the 2nd & 3rd bulk rings in that box as well as new bearings.
You WILL NOT have to replace all of them - only the 1st gear bulk ring.
It was in good serviceable condition & I did not see reason to replace it.
Obviously your different driving style (to me) nessatates it to be renewed...
It's NOT a job for you to do - you need to find someone who's familier with Zed gearbox's to do it.
I did listen to you.. I am only going to replace 1st... just wanted to know if i could do it or not... thanks.
If you have no experience with gearboxes then I would strongly recommend that you go to a gearbox reco business .
Replacement of syncros and bearings is straight forward however there are many tolerances that need to be measured and a trained eye to check what other components are worn (the ID of the coupling sleeves, shift fork wear , end play on the main cluster etc)  A Zed box is great when rebuilt properly but can be a dog if it is botched up.
Expect to pay around $1000 for a decent rebuild.
I have a brilliant gearbox builder her in Melbourne who rebuilds Z and Roadster boxes sent from all over Aust....PM me if you need his details
Old dogs for the hard road and PUPPIES for the pavement..........
I'm still learning... :P
He asked for help not criticism.
Take it to a specialist and see if he'll let you watch? Could learn a thing or two.
