It shows a JDM style install with no visible signs on the interior , other than a grey control under the steering wheel. Its shown in a disassembled state , but you get the idea
Uses a standard Sandem compressor on a semi-custom bracket, various off the shelf ( but all brand new) parts and custom made evaporator box. The evap was the hardest item to source as not even the smallest unit from a current car would fit , not even the smallest Suzukis or Toyotas
The local A/C shop crimped the hoses for me and gassed it all up - money well spent
I also upgraded the stock fan to the Honda one, as suggested on this forum
In hindsight, I can see why the JDM version did not make it beyond Japan - the in-dash space is simply too small to fit a full size evaporator, which leads me to believe why the 260 HVAC was completely redesigned, it has a much bigger, sturdier evap box
It works great in general, but I want to add either the full 240 stock radiator shroud (someone must have one , it was supposed to be standard on autos)
You can post now and register later.
If you have an account, sign in now to post with your account.
Question
aircobra
All those who helped me with my build over the years and have put up with my annoying question, here are shots of my completed mission
https://flic.kr/s/aHBqjApTdL
0 answers to this question
