Alex Posted January 19, 2006 Posted January 19, 2006 Surprise surprise, the floors need to be replaced on my 240z rusted through. just a question few questions about this ( bear in mind this is my first project car and im only good with mechanics i.e. still learning how to weld). Can you use 260 2+2 floor pans (cut shorter of coarse) to replace these? if not i'll just buy them, it'd just be cheaper for me which i know isn't a great thing to say but im on a pretty tight budget and secondly the rust damage to the floors has started creeping up the angled section behind the seat, the area you would normally weld the rear section of the floor pan. whats the best way to deal with that area? ( and sorry i dont know what its called. thanks guys AL - (novice restorer) Quote
Natez Posted January 20, 2006 Posted January 20, 2006 buy new pans and weld them in.... or get a place like Zworx to put them in for you, they do it everyday so they know what they are doing... Quote
Alex Posted January 20, 2006 Author Posted January 20, 2006 yeah i dont have a problem welding in new pans... or where to get them for that matter but where you would ordinarily weld the pan too has excessive rust. should i just cut that out and replace with sheet metal befor putting i the new floors? Quote
lambs Posted January 21, 2006 Posted January 21, 2006 yeah i dont have a problem welding in new pans... or where to get them for that matter but where you would ordinarily weld the pan too has excessive rust. should i just cut that out and replace with sheet metal befor putting i the new floors? You'll have to cut out all the rusted sheet and replace with new before welding in any replacement floors. From memory, 2+2 floor pans are quite different to 2-seater's, and not just in terms of length. They could probably be made to fit, but with all the mucking around and modification they'd need you'd probably be better getting new in the first place. Quote
Alex Posted January 21, 2006 Author Posted January 21, 2006 no worries, off to rarespares then cheers guys Al Quote
Alex Posted January 21, 2006 Author Posted January 21, 2006 ok rare spares just told me i can only get the front left and front right pans... what do i do about the rest of the floors? i.e. the section indernear the seat brackets? i had thought it was one piece? Quote
lambs Posted January 21, 2006 Posted January 21, 2006 ok rare spares just told me i can only get the front left and front right pans... what do i do about the rest of the floors? i.e. the section indernear the seat brackets? i had thought it was one piece? It is one piece from the factory, but the aftermarket suppliers probably only make pieces to repair the common problem areas. I'd suggest talking to one of the Z specialists about what is available to repair your problem areas - it might have to be custom made. Quote
warrenz Posted January 22, 2006 Posted January 22, 2006 Not sure what Rare Spares is selling but the one I bought from AllZparts for a 2 seater is 1100mm long and the rear seat brackets weld to the new pan. So unless your rusted parts of the underbody are where the it rises up to go over the diff and wheels or at the point where it starts to bend up a replacement pan should replace the whole floor. There is a really good thread on replacing floor pans and the pictures may answer your questions. Cheers Warren Quote
lambs Posted January 22, 2006 Posted January 22, 2006 So unless your rusted parts of the underbody are where the it rises up to go over the diff and wheels From the OP I took it that was the problem. Quote
