Posted (edited)
Not sure exactly which category door seals fits in on the forum admin please move if there's somewhere better to post.
Anyway I ordered a rubber kit from Rare Spares for the 260Z 2+2 restoration and the door seals are just a universal type door seal, the corner part for where the door meets the window section isn't there, would need to be made up somehow, and neither is the flat part that comes out and sits along the top of the door. Apart from the things it's missing it is pretty close to the original.
I was counting on it just being a complete ready to go in door seal and am now at a bit of a loss as to what to do. The corner part is something I could probably figure out but the piece that comes out above the window which doesn't even seem to be in the kit has thrown me and I certainly wasn't counting on having to pretty much build a seal out of nothing.
Would like some advice on it if anyone has any?
I'm thinking I might have to return the kit and source the rubber parts from somewhere else. The Rare Spares kit just seems to be incomplete. I did read somewhere on this forum that the 2+2 door seals need to be sourced from overseas and even then are hard to get.. I assume it's because of the parts missing from the readily available seals here?
Edited by RunawaySloth
I'm sure I'll be able to sort something out with some glue and a bit of experimentation. Will probably be able to cut out the top bits from the old seal and reuse them as fortunately they're undamaged.
