pauly_adams Posted August 14, 2008 Posted August 14, 2008 hey everyone i got myself another problem, today after putting on a new set of carbs i tryed to fire up the old girl it started but everytime i let the key go back into its running position it just cuts out as if i had turned it off, allough when i held it in between starting and running it ran fine. can any one tell me what is going on. cheers pauly Quote
Moderators Zedman240® Posted August 14, 2008 Moderators Posted August 14, 2008 Remove the electrical switch behind and make sure the ignition barrel tongue isnt broken or damaged. If not, you may need a new switch. Not the whole lock, just the switch behind. Or another test is remove the switch, and poke a flat blade screw driver in the center and try to start it that way. Quote
pauly_adams Posted August 15, 2008 Author Posted August 15, 2008 hey i fixed my problem it was my resistor one of the plugs came off, man do i have egg on my face in good news my new carbs work a treat. thanks for the advice zedman240 cheers pauly Quote
