Cranking the RB25 tonight to see if I got oil pressure (before I actually start the thing) but after about 2-3mins at starting speed I had no pressure. Usually after a few seconds the gauge should start climbing a little. The sender was from a old Patrol at the wreckers so I'm thinking that sender is farked. Is there a good way to test the sender off the engine to see if it registers any pressure? Or should I ditch it and just get another one? I grounded the wire to the block with the ignition on and the gauge read full so the gauge is working..Trying to save the pennies after forking out $2000 on the new Wolf ECU!
air pressure is more than good enough... but for something so vital!!! get a newie for 50 bucks or so you cant go wrong
