G'day - a quick question if anyone can help.
Trying to remove headlight nacelles from 1976 260z. Had the usual problem, one bolt came out, one snapped off, 2 appeared to have the welded nuts on inside of panel break free so I assume I will have to cut off the bolt heads and tac weld nuts back in place. So the question - is it 4 bolts in total, two on the inside near radiator and two on the outside or are there any other securing bolts behind the headlight?
Thanks
