mca_nick Posted June 26, 2008 Posted June 26, 2008 Car is located in Launceston, Tasmania 1975 Datsun 260Z 2+2 Completely std, except for exhaust (extractors into 2"), ignition (push button due to broken ign. barrel), and air con (removed) Original engine and box. 5-speed manual Excellent mechanical condition, engine has recently been tuned by dougin & parker (l'ton) with new filters, spark plugs, leads, rocker cover gasket, points, and re-set timing. Good comp on all cylinders. Body is immaculate, totally straight with NO rust. Interior is very good with re-trimmed dash and drivers seat. All vinal is perfect except a split seam in drivers seat. Odo says 66,000km, but it's only 5 dig so that doesn't mean much... Tas rego till 17/10/08 Issues: I've put her through a RACT Mech Insp. and a Pedders Suspension check and these are the issues... Suspension: tie rod ends, radius bushes, rear shocks, and all bump stops are worn and rear tires are bald. Mechanical: Some electrical issues (will be fixed before sale), rear demister and clock don't work, movement in rear drive shaft's uni joint. At the moment there's no carpet, i'll have this fitted if the buyer desires. The car was recently resprayed and while the paint is in excellent condition, it wasn't the best job in the world... looking for offers over $7000, this is a very clean example. *original front end has been re-fitted since photos.* i'm not on this site much so if you're interested my email is nhclark@utas.edu.au may be interested in a swap for something interesting/smaller/cheaper cheers, nick Quote
stevo_gj Posted June 26, 2008 Posted June 26, 2008 Beautiful Zed mate, good luck selling it. 7K is a very good price! -Steve Quote
