Hood280zx Posted December 5, 2018 Posted December 5, 2018 Hey team, Just having an issue with the handbrake on the drivers side, even with the lever on full lock I can't get any purchase on the disc. The left side is fine and locks things up nicely. Any advice on adjusting the lever/calliper would be sweet. Attached some videos for you to explain it a bit better. Cheers, Hoody Leftside.mp4 Rightside.mp4 Quote
Claude Posted September 19, 2019 Posted September 19, 2019 Hey Hoody, did you sort this out? I'm having a similar problem. I'm suspecting the mechanism inside the caliper behind the piston. Quote
Hood280zx Posted September 26, 2019 Author Posted September 26, 2019 Hey mate, From what I remember we had to wind out the piston manually as the brakes don't have an automatic spring-loaded adjuster on them, worked fine after that Quote
Hokin Posted September 30, 2019 Posted September 30, 2019 Might also be worth getting the back half of the handbrake cable out of the car and soaking it in crc/inox and manually moving it back and forth. We had an issue with mine not wanting to apply a few years back and it had massive amounts of rubbish inside the sheath protecting the cable. After a few hours and getting a bunch of dirt out it worked a lot better afterwards. This was very helpful: https://www.supercheapauto.com.au/p/bike-service-bs-cable-wire-lubrication-tool/SPO1893401.html Hood280zx 1 Quote
