Wanted 260Z Wiring Harness Interior And Manual Pedal Box
It's 1975, but I have dash out of earlier on, I have a really good loon but I'd say it's off a earlier model, as there is a shorter loom to go to ignition, where the one I have is built into loom,
Ignition loom should be same length. Wiring colour codes and plugs/terminals did change over the years.
If you have, say, a '74 loom especially an early one then I'm sure it's different to a '75-on. Best to track a '75/76 loom to match the rest of the car.
AFAIK the pedal box is the same, you just need the pedals.
Well I can tell you the harness I have is different to the one that was in it by a great deal. Which is a shame as the 260z loom is perfect just need the right plug. I know the 260z
