Hi Mate
What are you after? The engine cross member, the metal engine bracket(the bracket that goes from the engine to the rubber mount, if so which side as they are different) or the rubber engine mount?
Your in luck as I have all of these components.
Greg
Hi yeah I need the metal piece that the engine sits on. that bolts to the chassis. And the steering rack and suspension bolts to. Pm me where you are located. I'll take everything you have for the crossmember. Cheers I'm in Melbourne.
