JP240z Posted November 1, 2005 Posted November 1, 2005 Having trouble with VicRoads, Need to be able to locate the serial number of the 240z before registration. The car has been body deadened and finding the serial number is going to be tough without any direction. Any recommendations would be handy. Cheers JP. Quote
Natez Posted November 1, 2005 Posted November 1, 2005 serial number......the car doesnt have a serial number printed on it, that number would come from prevous registration papers the numbers that are on the car are chasis numbers... which are on the plate inside the engine bay... or engraved on the drivers side of the firewall, starting with S30??? the engine number is on the engine block, drivers side, top of the block closest to the firewall, and should start with L24, or L26 or L28 if u are transfering registration then u should get the serial off the prevous owner, if u are registering the car urself after registration has been voided thenyou shouldn't need a serial number they will give you a new one... Quote
Zeddophile Posted November 1, 2005 Posted November 1, 2005 The VIN number will be engraved on the firewall, as Natez said. On my 260, it starts above the brake booster - start of number lines up almost dead centre of the booster. If its painted over, get a wire brush on a drill and start stripping back there - assuming of course its not stamped on the compliance plate, or the vehicle plate. Quote
