Groundhog Posted November 16, 2016 Posted November 16, 2016 I'm chasing a L-series harmonic balancer that suits a 16 mm Air Con drive and 13 mm water pump drive.Standard L26 factory air con set up. Small 16 mm front pulley, larger 13 mm rear. Prefer new or one that has seen very little use.GH. Quote
280zUSA Posted November 20, 2016 Posted November 20, 2016 I have a bmw balancer if that will work? Quote
Groundhog Posted November 20, 2016 Author Posted November 20, 2016 Thanks for the reply. It may be a fall back option if the ATI damper I have bought doesn't workout. I contacted ATI directly to confirm if it was possible to add another vee belt pulley to their damper. The response was that they add Chevy big block pulleys to this damper so you can add another pulley.It just won't have the same alignment for the a/c so I will have to modify the compressor mount to suit. The damper I purchased is the 918040The hub that it mounts to is being sorted with LCR. I'll update this post as the build progresses.http://www.atiracing.com/products/dampers/charts/damnissan.htm Quote
