2+2 panels from base of windscreen forwards will fit on 2 seater, anything behind there is different.
Rear quarter skins - is it the whole quarter you need, or just the dogleg at the bottom?  I believe the dogleg is available, but if you want a whole quarter, you'll have to buy a shell to pull them off (and believe me, it is NOT a small job to change rear quarters, and should be avoided if not completely necessary).
