Glen Posted February 23, 2008 Posted February 23, 2008 hello, My problem is no indicators, i pulled the assembly apart and found the switch to be very grimey. i cleaned it and put it back together to find i now have RH but the LH. LH only works if i exert pressuse to negative connection on the switch board. All the connection points seems to line up but for some reason theres no action. Using a screw driver on the back of the exposed side and the indicators work fine. Im at a loss so im looking for another switch if possible or another idea of how i should be going about this. Ths all belongs to a 77 aswell. cheers glen Quote
matt drago Posted February 24, 2008 Posted February 24, 2008 Hey Glen, To help others that may have this problem in the future, how about you let us in on the actual solution. Cheers, Matt Quote
Glen Posted February 24, 2008 Author Posted February 24, 2008 No worries, will do tomorrow with photos Quote
Glen Posted February 24, 2008 Author Posted February 24, 2008 As the picture shows the stalk is in LH indicator mode, I opened up the screws to see what was happening. I noticed after a little playing that when it moved into this position it would flex the negative points away from each other. Only by a fraction. This is the result of the LH positive points being oversized and thus forcing negative points apart. It's hard to see in the picture but there is a large gap there. My first solution was to bend the board a little, i broke it but some 406 put it back together. So what i did was carefully file away on the LH copper point untill it stopped moving the 2 negative points away from each other. After 10 to 12 goes i finally got it just right. Before i did any fileing i would press on the negative points and use my force as a indicator to see how much further i had to go. As i filed more less force was required. Also the white wire isnt my dogdey work lol Quote
