Posted (edited)
Hey guys.
I have recently removed the engine from my 260z 2+2 gave it a little cleanup and engine bay cleanup. I put the wiring harness in split tube and added wiring for thermo fans (seperate from original harness). The problem I am having is I have no heater, fuel pump or starter motor. With the ignition turned on I have power to starter/alternator but not to the fuel pump. I am having trouble finding a wiring diagram as most are either US or are not for a 76.
I have checked all my engine bay grounds and all are good (checked resistance with multimeter) I even added more just incase.
All wireing was working previous to engine being removed.
Is it possibly something like the ignition relay or another relay, or even the fusible link on the ignition side ?
Thanks guys
Edited by blu260z
